소개
The rechargeable battery used in this device is one of the components most likely to fail. Fortunately the replacement process is simple and straightforward. Follow this guide for a pain-free battery replacement experience.
필요한 것
Place the unit face down as shown in the picture, exposing the battery cover.
Remove the two 4.0mm long screws holding the cover on using a T10 driver.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 3개
This one should work: https://vintrons.com/products/marshall-t...
Kai Hattan - 답글
Hi, does anybody know how to recharge the battery external, because something on the platina fried (LL10) component, and it want charge through the killburn, but works fine with battery. Thank you
