주요 콘텐츠로 건너뛰기
Marshall Woburn Tweeter Replacement
필요한 것
  1. Marshall Woburn Tweeter Replacement, Back Panel: 1 단계, 이미지 1/2 Marshall Woburn Tweeter Replacement, Back Panel: 1 단계, 이미지 2/2
    • Before starting, unplug the speaker from any power source. After unplugging the device, wait around 10 minutes before starting to let the capacitor fully discharge.
    • On a flat surface, orient the device so that the front grille is facing downward.
    • Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
    • Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
  2. Marshall Woburn Tweeter Replacement: 2 단계, 이미지 1/2 Marshall Woburn Tweeter Replacement: 2 단계, 이미지 2/2
    • Lift the back input board slightly above the back panel.
    • Rotate the input board so that you can slide it into the hole in the back panel that it came from.
    • Fully slide the input board through the back panel and set it down gently inside the speaker.
  3. Marshall Woburn Tweeter Replacement: 3 단계, 이미지 1/1
    • Grab the panel by the large hole and lift one side until you can fit your hand under.
    • Use your hand to fully remove the back panel from the rest of the frame.
  4. Marshall Woburn Tweeter Replacement, I/O Board: 4 단계, 이미지 1/1
    • Disconnect the 5 wires circled in red from the back input board.
    • There may be a little resistance when pulling on the wires, but it should not require excessive force.
  5. Marshall Woburn Tweeter Replacement: 5 단계, 이미지 1/2 Marshall Woburn Tweeter Replacement: 5 단계, 이미지 2/2
    • Remove the two 12.7 mm screws marked in red from the front of the back input panel with a Phillips #1 screwdriver.
    • Remove the power input from the back side of the panel.
  6. Marshall Woburn Tweeter Replacement: 6 단계, 이미지 1/1
    • Completely remove the I/O board and the attached plate.
  7. Marshall Woburn Tweeter Replacement, Tweeter: 7 단계, 이미지 1/1
    • Using a Phillips #1 screwdriver, remove the eight 15.8 mm screws attaching the tweeters to the frame.
    • Disconnect the two wires from the back of each tweeter.
  8. Marshall Woburn Tweeter Replacement: 8 단계, 이미지 1/1
    • Lift the tweeter from the frame to remove it.
결론
Kenneth
회원 가입일: 10/29/23
169 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023 회원
UMASSD-GULBRANDSEN-F23S2G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 19
전체 시간: 113
