주요 콘텐츠로 건너뛰기
Martian Victory Watch band Replacement
필요한 것
  1. Martian Victory Watch band Replacement, Watch band: 1 단계, 이미지 1/1
    • Take the watch band removal tool and insert it in the small slit between watch bezel and the band, resting up against the bezel.
  2. Martian Victory Watch band Replacement: 2 단계, 이미지 1/1
    • Press down of the shaft that holds the band on, while simultaneously dragging the tip of the tool back towards the band in order to compress the spring bar that holds the band on.
    • Drag the tip of the tool away from the bezel while still pressing down in order to remove the shaft from the bezel.
    • The spring shaft may decompress once its out of the bezel and try to shoot away.
  3. Martian Victory Watch band Replacement: 3 단계, 이미지 1/1
    • Repeat these steps on the other side of the band to completely remove the band, ready for cleaning or replacement.
결론
Dominic Coffey
회원 가입일: 10/24/16
243 평판
안내서 2개 작성하였습니다
IUPUI, Team 3-3, Baechle Fall 2016 IUPUI, Team 3-3, Baechle Fall 2016 회원
IUPUI-BAECHLE-F16S3G3
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 14
전체 시간: 295
