소개
This guide explains all the steps for taking apart the device, taking out the old auxiliary port from the device and soldering on a new one. This guide requires basic soldering knowledge and if done improperly may cause injury to the user. People with physical hand or wrist disabilities be cautioned that you may need to consider asking someone else to replace the part for you so you do not injure yourself.
필요한 것
Remove two of the three screws shown on the bottom of the device.
Begin removing the last screw, but leave it partially in the socket to remove the bottom cover easier.
이 단계에 사용된 도구:Tweezers$4.99
Locate the auxiliary port on the top side of the circuitboard.
On the bottom of the circuitboard, locate the metal pin connecting the auxiliary port to the circuitboard.
Use the soldering iron to disconnect the pin.
Use a pair of tweezers to remove the old auxiliary port.
Place the new auxiliary port in the same spot and solder the port to the circuitboard.
