주요 콘텐츠로 건너뛰기
Marvel iHome MR-M66 Back Cover Replacement
필요한 것
  1. Marvel iHome MR-M66 Back Cover Replacement, Back Cover: 1 단계, 이미지 1/2 Marvel iHome MR-M66 Back Cover Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove two of the three screws shown on the bottom of the device.
    • Begin removing the last screw, but leave it partially in the socket to remove the bottom cover easier.
  2. Marvel iHome MR-M66 Back Cover Replacement: 2 단계, 이미지 1/3 Marvel iHome MR-M66 Back Cover Replacement: 2 단계, 이미지 2/3 Marvel iHome MR-M66 Back Cover Replacement: 2 단계, 이미지 3/3
    • Remove the bottom cover by either pulling on the screw or using a plastic opening tool to pry the cover off.
    • After removing the bottom cover, remove the two screws.
  3. Marvel iHome MR-M66 Back Cover Replacement: 3 단계, 이미지 1/3 Marvel iHome MR-M66 Back Cover Replacement: 3 단계, 이미지 2/3 Marvel iHome MR-M66 Back Cover Replacement: 3 단계, 이미지 3/3
    • Use a spudger to release the small retaining clip that holds the feet to the bottom of the device.
    • Be careful here, as too much force can break the clip.
    • Remove the two screws from the back of the device.
  4. Marvel iHome MR-M66 Back Cover Replacement: 4 단계, 이미지 1/3 Marvel iHome MR-M66 Back Cover Replacement: 4 단계, 이미지 2/3 Marvel iHome MR-M66 Back Cover Replacement: 4 단계, 이미지 3/3
    • Using a plastic opening tool and your hand, separate the front and back covers from each other.
    • Starting from the bottom, use the plastic opening tool to create the initial separation and continue along the seam to the top of the device.
    • This step requires the most time and patience, so be careful.
    • The power switch will most likely come loose during this step and you will hear something rattling inside the device.
  5. Marvel iHome MR-M66 Back Cover Replacement: 5 단계, 이미지 1/3 Marvel iHome MR-M66 Back Cover Replacement: 5 단계, 이미지 2/3 Marvel iHome MR-M66 Back Cover Replacement: 5 단계, 이미지 3/3
    • Remove the two arms from either side of the device once a significant separation has been created.
    • They are not fixed to the body itself so you should be able to wiggle them free.
    • Continue pulling the back cover off the device.
    • Remove the red cover for the on/off switch from the device.
결론
Aaram Williams
회원 가입일: 03/08/17
201 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S5-G3, Botvin Spring 2017 UMass Dartmouth, Team S5-G3, Botvin Spring 2017 회원
UMASSD-BOTVIN-S17S5G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 122
