주요 콘텐츠로 건너뛰기
Matchbox Dino Trapper Trailer Eyes Replacement
필요한 것
  1. Matchbox Dino Trapper Trailer Eyes Replacement, Eyes: 1 단계, 이미지 1/1
    • Open the jaw of the T-Rex to reveal the screw on the roof of its mouth.
  2. Matchbox Dino Trapper Trailer Eyes Replacement: 2 단계, 이미지 1/1
    • Using a JIS #1 screwdriver, remove the 9.6mm screw.
  3. Matchbox Dino Trapper Trailer Eyes Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using tweezers or wire cutters for tension, remove the cover to reveal the LED assembly.
  4. Matchbox Dino Trapper Trailer Eyes Replacement: 4 단계, 이미지 1/1
    • Remove the plastic cover from the top of the LED.
  5. Matchbox Dino Trapper Trailer Eyes Replacement: 5 단계, 이미지 1/1
    • Hold the LED to remove slack from the wires, and cut the wires as shown to remove the faulty LED.
결론
To reassemble your device, follow these instructions in reverse order. Use a soldering station to solder new LED onto the fresh-cut wires.
Vincent Crabtree
회원 가입일: 03/27/18
267 평판
안내서 2개 작성하였습니다
IUPUI, Team S3-G3, Harley Spring 2018 IUPUI, Team S3-G3, Harley Spring 2018 회원
IUPUI-HARLEY-S18S3G3
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 7
전체 시간: 254
