소개
This is a guide to remove the Camera for the Matsunichi M97 9in tablet. To use this guide you will need a spudger, or an iFixit opening tool, a Phillips 00 Screwdriver, and tweezers. This guide requires the Battery Removal Guide, and the Motherboard Removal Guide as prerequisites.
필요한 것
Remove the six 2mm screws that hold the motherboard onto the case using the Phillips #00 screwdriver.
Use the same screwdriver to remove the single 4mm screw.
거의 끝나갑니다!
결론
