주요 콘텐츠로 건너뛰기
Matsunichi M97 9 inch Camera Replacement
필요한 것
  1. Matsunichi M97 9 inch Camera Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Open the micro SD cover located on the back of the device.
  2. Matsunichi M97 9 inch Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Using the Phillips #00 screwdriver, remove the two 4mm screws next to the micro SD port.
  3. Matsunichi M97 9 inch Camera Replacement: 3 단계, 이미지 3개 중 1개 Matsunichi M97 9 inch Camera Replacement: 3 단계, 이미지 3개 중 2개 Matsunichi M97 9 inch Camera Replacement: 3 단계, 이미지 3개 중 3개
    • Use the iFixit opening tool to pry off the back cover of the device.
    • The volume buttons and the lock switch will come loose when the back comes off.
  4. Matsunichi M97 9 inch Camera Replacement: 4 단계, 이미지 2개 중 1개 Matsunichi M97 9 inch Camera Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to disconnect the battery from the motherboard.
  5. Matsunichi M97 9 inch Camera Replacement: 5 단계, 이미지 2개 중 1개 Matsunichi M97 9 inch Camera Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully unstick the battery from the frame using the spudger.
    • Do not bend or puncture the battery during removal.
  6. Matsunichi M97 9 inch Camera Replacement, Motherboard: 6 단계, 이미지 2개 중 1개 Matsunichi M97 9 inch Camera Replacement, Motherboard: 6 단계, 이미지 2개 중 2개
    • Remove the six 2mm screws that hold the motherboard onto the case using the Phillips #00 screwdriver.
    • Use the same screwdriver to remove the single 4mm screw.
  7. Matsunichi M97 9 inch Camera Replacement: 7 단계, 이미지 2개 중 1개 Matsunichi M97 9 inch Camera Replacement: 7 단계, 이미지 2개 중 2개
    • Gently pull the display ribbon cable to unplug it from the motherboard.
  8. Matsunichi M97 9 inch Camera Replacement: 8 단계, 이미지 1개 중 1개
    • Use a spudger or an iFixit opening tool to lift the locking mechanism holding the camera ribbon cable.
  9. Matsunichi M97 9 inch Camera Replacement: 9 단계, 이미지 2개 중 1개 Matsunichi M97 9 inch Camera Replacement: 9 단계, 이미지 2개 중 2개
    • Lift up on the wifi antenna cable to unsnap it from the motherboard.
    • Then unhook the cable from the holding bracket.
  10. Matsunichi M97 9 inch Camera Replacement: 10 단계, 이미지 2개 중 1개 Matsunichi M97 9 inch Camera Replacement: 10 단계, 이미지 2개 중 2개
    • Use the spudger or iFixit opening tool to lift up on the locking mechanism for the digitizer ribbon cable.
    • Pull the cable from its connection.
  11. Matsunichi M97 9 inch Camera Replacement: 11 단계, 이미지 2개 중 1개 Matsunichi M97 9 inch Camera Replacement: 11 단계, 이미지 2개 중 2개
    • Use the Phillips #00 screwdriver to remove the four 4mm screws that hold the speakers in place.
  12. Matsunichi M97 9 inch Camera Replacement: 12 단계, 이미지 1개 중 1개
    • Pull the vibration motor out of its housing.
  13. Matsunichi M97 9 inch Camera Replacement: 13 단계, 이미지 2개 중 1개 Matsunichi M97 9 inch Camera Replacement: 13 단계, 이미지 2개 중 2개
    • Lift the motherboard off the frame.
  14. Matsunichi M97 9 inch Camera Replacement, Camera: 14 단계, 이미지 2개 중 1개 Matsunichi M97 9 inch Camera Replacement, Camera: 14 단계, 이미지 2개 중 2개
    • Remove the camera from the device.
결론
작성자
3다른 기여자 명과 함께
Violet Ruff
회원 가입일: 01/16/20
99 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 76
