주요 콘텐츠로 건너뛰기
Matsunichi M97 9 inch Motherboard Replacement
필요한 것
  1. Matsunichi M97 9 inch Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Open the micro SD cover located on the back of the device.
  2. Matsunichi M97 9 inch Motherboard Replacement: 2 단계, 이미지 1/1
    • Using the Phillips #00 screwdriver, remove the two 4mm screws next to the micro SD port.
  3. Matsunichi M97 9 inch Motherboard Replacement: 3 단계, 이미지 1/3 Matsunichi M97 9 inch Motherboard Replacement: 3 단계, 이미지 2/3 Matsunichi M97 9 inch Motherboard Replacement: 3 단계, 이미지 3/3
    • Use the iFixit opening tool to pry off the back cover of the device.
    • The volume buttons and the lock switch will come loose when the back comes off.
  4. Matsunichi M97 9 inch Motherboard Replacement: 4 단계, 이미지 1/2 Matsunichi M97 9 inch Motherboard Replacement: 4 단계, 이미지 2/2
    • Use a pair of tweezers to disconnect the battery from the motherboard.
  5. Matsunichi M97 9 inch Motherboard Replacement: 5 단계, 이미지 1/2 Matsunichi M97 9 inch Motherboard Replacement: 5 단계, 이미지 2/2
    • Carefully unstick the battery from the frame using the spudger.
    • Do not bend or puncture the battery during removal.
  6. Matsunichi M97 9 inch Motherboard Replacement, Motherboard: 6 단계, 이미지 1/2 Matsunichi M97 9 inch Motherboard Replacement, Motherboard: 6 단계, 이미지 2/2
    • Remove the six 2mm screws that hold the motherboard onto the case using the Phillips #00 screwdriver.
    • Use the same screwdriver to remove the single 4mm screw.
  7. Matsunichi M97 9 inch Motherboard Replacement: 7 단계, 이미지 1/2 Matsunichi M97 9 inch Motherboard Replacement: 7 단계, 이미지 2/2
    • Gently pull the display ribbon cable to unplug it from the motherboard.
  8. Matsunichi M97 9 inch Motherboard Replacement: 8 단계, 이미지 1/1
    • Use a spudger or an iFixit opening tool to lift the locking mechanism holding the camera ribbon cable.
  9. Matsunichi M97 9 inch Motherboard Replacement: 9 단계, 이미지 1/2 Matsunichi M97 9 inch Motherboard Replacement: 9 단계, 이미지 2/2
    • Lift up on the wifi antenna cable to unsnap it from the motherboard.
    • Then unhook the cable from the holding bracket.
  10. Matsunichi M97 9 inch Motherboard Replacement: 10 단계, 이미지 1/2 Matsunichi M97 9 inch Motherboard Replacement: 10 단계, 이미지 2/2
    • Use the spudger or iFixit opening tool to lift up on the locking mechanism for the digitizer ribbon cable.
    • Pull the cable from its connection.
  11. Matsunichi M97 9 inch Motherboard Replacement: 11 단계, 이미지 1/2 Matsunichi M97 9 inch Motherboard Replacement: 11 단계, 이미지 2/2
    • Use the Phillips #00 screwdriver to remove the four 4mm screws that hold the speakers in place.
  12. Matsunichi M97 9 inch Motherboard Replacement: 12 단계, 이미지 1/1
    • Pull the vibration motor out of its housing.
  13. Matsunichi M97 9 inch Motherboard Replacement: 13 단계, 이미지 1/2 Matsunichi M97 9 inch Motherboard Replacement: 13 단계, 이미지 2/2
    • Lift the motherboard off the frame.
결론
Christopher
회원 가입일: 01/16/20
249 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 92
