주요 콘텐츠로 건너뛰기
Matsunichi MarquisPad MP977 Front Facing Camera Replacement
필요한 것
  1. Matsunichi MarquisPad MP977 Front Facing Camera Replacement, Front Facing Camera: 1 단계, 이미지 1/1
    • Using the PH #00 Phillips head screwdriver, unscrew the two screws.
  2. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 2 단계, 이미지 1/3 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 2 단계, 이미지 2/3 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 2 단계, 이미지 3/3
    • Place the device face down on a flat surface.
    • Insert the wide-tipped plastic opening tool into the top of the left speaker slot.
    • Be sure not to puncture the covering of the speaker.
    • Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and the back plate until you reach the power button.
  3. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 3 단계, 이미지 1/2 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 3 단계, 이미지 2/2
    • Insert the opening tool into the slot located to the right of the speaker, at the top edge of the device.
    • Then, pry open the back plate of the device , and slide the tool counter clockwise along the device until you reach the charging port.
  4. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 4 단계, 이미지 1/1
    • Remove the back plate and place it to the side of the device.
  5. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 5 단계, 이미지 1/1
    • With the same screw driver, PH #00 Phillips head, remove the seven screws holding in the motherboard.
    • Place the screws somewhere safe where they wont fall.
  6. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 6 단계, 이미지 1/2 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 6 단계, 이미지 2/2
    • Gently pull the camera optic fiber out of it's slot to release the flap. This will allow the flap to open easily.
    • Be sure not to damage the camera port.
  7. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 7 단계, 이미지 1/2 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 7 단계, 이미지 2/2
    • Last, Insert the new camera into the pinhole camera slot.
결론
Kathryn Sherlock
회원 가입일: 03/24/15
127 평판
안내서 1개 작성함
UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015 회원
UMASSD-VIJAYBHASKAR-S15S4G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 240
