주요 콘텐츠로 건너뛰기
Matsunichi MarquisPad MP977 Plastic Front Panel Replacement
필요한 것
  1. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement, Plastic Front Panel: 1 단계, 이미지 1/1
    • Remove the two screws using a PH #00 Phillips head screw driver.
  2. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: 2 단계, 이미지 1/3 Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: 2 단계, 이미지 2/3 Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: 2 단계, 이미지 3/3
    • Place the device face down on a flat surface.
    • Insert one of the wide tipped, plastic opening tools into the top of the left speaker slot.
    • Be sure not to puncture the covering of the speaker.
    • Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and its back plate until you reach the power button.
  3. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: 3 단계, 이미지 1/2 Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: 3 단계, 이미지 2/2
    • Insert opening tool into the right speaker slot.
    • Pry open the back plate, and slide the tool counter clockwise along the device until you reach the charging port.
  4. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: 4 단계, 이미지 1/1
    • Remove the back plate and place it to the side.
  5. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: 5 단계, 이미지 1/1
    • Remove the screws holding the metal frame plate in place.
    • Remove the metal frame plate from the plastic housing.
  6. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: 6 단계, 이미지 1/2 Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: 6 단계, 이미지 2/2
    • Place the metal frame plate and components into the new plastic front panel.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Rachel Servis
회원 가입일: 03/24/15
89 평판
안내서 1개 작성함
UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015 회원
UMASSD-VIJAYBHASKAR-S15S4G1
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
where can you order the front plastic panel from? and how much?
daf01ca - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 380
