주요 콘텐츠로 건너뛰기
MaxWest TAB-7360DC Motherboard Replacement
필요한 것
  1. MaxWest TAB-7360DC Motherboard Replacement, Back Hard Case: 1 단계, 이미지 3개 중 1개 MaxWest TAB-7360DC Motherboard Replacement, Back Hard Case: 1 단계, 이미지 3개 중 2개 MaxWest TAB-7360DC Motherboard Replacement, Back Hard Case: 1 단계, 이미지 3개 중 3개
    • Insert plastic opening tool at the corner of the screen, in between the back case and the front.
    • Volume buttons will fall out during removal.
    • When opening up the case, have the I/O ports facing you and turn the back case towards the right. There is a short wire connecting the speaker to the logic board.
  2. MaxWest TAB-7360DC Motherboard Replacement: 2 단계, 이미지 2개 중 1개 MaxWest TAB-7360DC Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Carefully pry the tape from the battery, the bottom left chip, and the ribbon cable towards the bottom-right of the board. The bottom left has a little silver square component that must also be unclipped and untaped.
    • The battery is glued to the back of the screen; therefore pull the battery off of the back with caution. There will be resistance but that's okay.
  3. MaxWest TAB-7360DC Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Gently unclip the data cable retainers and remove the wires from the junctions.
    • Peel the tape off the wire near the bottom of the case.
  4. MaxWest TAB-7360DC Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the two 4mm screws (circled in orange) with a 00 Phillips head driver.
    • Unclip the black plastic retainer near the data port. The PCB should now be able to be gently pulled off.
  5. MaxWest TAB-7360DC Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Make contact with the battery terminals with the hot tip of the soldering iron for a few seconds while slowly pulling the wire away.
    • DO NOT TOUCH BOTH THE BLACK AND RED LEADS AT THE SAME TIME WITH THE SOLDERING IRON
  6. MaxWest TAB-7360DC Motherboard Replacement, Motherboard: 6 단계, 이미지 2개 중 1개 MaxWest TAB-7360DC Motherboard Replacement, Motherboard: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • With the tweezers, grab onto the gray part of the ribbon clamps and pull away from the ribbons.
    • Once the ribbons are unclamped, they are able to slide out.
결론
작성자
2다른 기여자 명과 함께
Clint Crabb
회원 가입일: 03/26/18
133 평판
안내서 1개를 작성함
IUPUI, Team S4-G3, Baechle Spring 2018 IUPUI, Team S4-G3, Baechle Spring 2018 회원
IUPUI-BAECHLE-S18S4G3
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 356
