주요 콘텐츠로 건너뛰기
Mayfan Joy-con for Switch - Repair of shoulder button
필요한 것
  1. Mayfan Joy-con for Switch - Repair of shoulder button, Mayfan Joy-con for Switch - Repair of shoulder button: 1 단계, 이미지 2개 중 1개 Mayfan Joy-con for Switch - Repair of shoulder button, Mayfan Joy-con for Switch - Repair of shoulder button: 1 단계, 이미지 2개 중 2개
    • Use a J0 Philips screwdriver to carefully remove the four screws. Screw head strips easily. Do not force it.
  2. Mayfan Joy-con for Switch - Repair of shoulder button: 2 단계, 이미지 1개 중 1개
    • Use a pry tool to open the controller once the screws are removed. The plastic cover for the shoulder button will most likely fall out. There are no springs on this button.
  3. Mayfan Joy-con for Switch - Repair of shoulder button: 3 단계, 이미지 1개 중 1개
    • The button will be bent back. This is especially visible from the front. You will see a gap between PCB and the button. Use some needle-nose pliers to bend the button back such that it is flush with the PCB.
결론
To reassemble your device insert the shoulder button cover, and follow these instructions in reverse order.
Note: With additional drops the button will bend again and eventually break. The way it is mounted is a bad mechanical design.
작성자
2다른 기여자 명과 함께
D3vMarc
회원 가입일: 06/20/22
97 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 16
전체 시간: 1,158
