주요 콘텐츠로 건너뛰기
Maylong M-270 Motherboard Replacement
필요한 것
  1. Maylong M-270 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 Maylong M-270 Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Use the plastic opening tool to separate the back cover plate from the front.
    • Insert the plastic opening tool in between the back plate cover and the top cover, then slide along edges to pry open.
  2. Maylong M-270 Motherboard Replacement: 2 단계, 이미지 1/2 Maylong M-270 Motherboard Replacement: 2 단계, 이미지 2/2
    • Locate the two ribbons attached to the device's motherboard.
    • Flip the small black plastic catches down by using the small end of the spudger.
    • Remove the ribbons by gently pulling them away from the motherboard.
  3. Maylong M-270 Motherboard Replacement: 3 단계, 이미지 1/2 Maylong M-270 Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove the two screws from the motherboard.
    • Remove the four screws and metal holds from the edge of the device.
  4. Maylong M-270 Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the motherboard by gently pulling it away from the bottom of the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Adam Sanders
회원 가입일: 03/24/15
222 평판
안내서 2개 작성하였습니다
University of Alabama, Team 1-3, Naidoo Spring 2015 University of Alabama, Team 1-3, Naidoo Spring 2015 회원
UA-NAIDOO-S15S1G3
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 533
