주요 콘텐츠로 건너뛰기
Maylong MN-1000P Keyboard Replacement
필요한 것
  1. Maylong MN-1000P Keyboard Replacement, Bottom Cover: 1 단계, 이미지 1/1
    • Place the netbook top down, with the opening of the netbook facing you.
  2. Maylong MN-1000P Keyboard Replacement: 2 단계, 이미지 1/1
    • Remove the six 6mm Phillips #00 screws from the netbook.
  3. Maylong MN-1000P Keyboard Replacement: 3 단계, 이미지 1/3 Maylong MN-1000P Keyboard Replacement: 3 단계, 이미지 2/3 Maylong MN-1000P Keyboard Replacement: 3 단계, 이미지 3/3
    • Remove the sticker in the middle of the netbook.
    • Remove the middle 6mm Phillips #00 screw.
  4. Maylong MN-1000P Keyboard Replacement: 4 단계, 이미지 1/1
    • Using two plastic opening tools, pry off the bottom of the netbook by going around the edges.
  5. Maylong MN-1000P Keyboard Replacement: 5 단계, 이미지 1/1
    • Remove the bottom of the netbook by lifting the corners.
  6. Maylong MN-1000P Keyboard Replacement, Battery: 6 단계, 이미지 1/2 Maylong MN-1000P Keyboard Replacement, Battery: 6 단계, 이미지 2/2
    • Pinch the red and black wires connected to the section closest to the small white connector, and pull to remove them from the motherboard.
  7. Maylong MN-1000P Keyboard Replacement, Screen: 7 단계, 이미지 1/1
    • Remove the six 6mm Phillips #00 screws from both sides of the netbook.
  8. Maylong MN-1000P Keyboard Replacement: 8 단계, 이미지 1/2 Maylong MN-1000P Keyboard Replacement: 8 단계, 이미지 2/2
    • Pull the top of the computer and the back side of the computer away from each other until they are detached.
    • Flip the entire computer over so you can see both the screen and keyboard.
  9. Maylong MN-1000P Keyboard Replacement: 9 단계, 이미지 1/2 Maylong MN-1000P Keyboard Replacement: 9 단계, 이미지 2/2
    • Remove all the black circular pads from around the screen.
    • Remove all 6mm Phillips #00 screws from around the screen bezel.
  10. Maylong MN-1000P Keyboard Replacement: 10 단계, 이미지 1/1
    • Using a plastic opening tool, pry off the screen bezel.
    • After detaching the screen bezel, pull up on the bezel near the hinge area.
  11. Maylong MN-1000P Keyboard Replacement: 11 단계, 이미지 1/1
    • Use tweezers to gently pull on the black and white wires at the top of the netbook until the white connector detaches.
  12. Maylong MN-1000P Keyboard Replacement: 12 단계, 이미지 1/1
    • Use your fingers to pull on the green, red, black, and white intertwined wires at the bottom of the netbook until the white connector detaches.
  13. Maylong MN-1000P Keyboard Replacement: 13 단계, 이미지 1/3 Maylong MN-1000P Keyboard Replacement: 13 단계, 이미지 2/3 Maylong MN-1000P Keyboard Replacement: 13 단계, 이미지 3/3
    • Detach the wide yellow ribbon cable connected to the screen from the computer.
  14. Maylong MN-1000P Keyboard Replacement: 14 단계, 이미지 1/2 Maylong MN-1000P Keyboard Replacement: 14 단계, 이미지 2/2
    • Flip the computer over.
    • Disconnect the red, green, black, and white intertwined wires from the connector to the motherboard.
  15. Maylong MN-1000P Keyboard Replacement: 15 단계, 이미지 1/3 Maylong MN-1000P Keyboard Replacement: 15 단계, 이미지 2/3 Maylong MN-1000P Keyboard Replacement: 15 단계, 이미지 3/3
    • Remove the black tape holding down the red, green, black, and white intertwined wires.
    • Remove the screen.
  16. Maylong MN-1000P Keyboard Replacement, Motherboard: 16 단계, 이미지 1/1
    • Remove the six 6mm Phillips #00 screws from the motherboard.
  17. Maylong MN-1000P Keyboard Replacement: 17 단계, 이미지 1/1
    • Remove the two 6mm silver screws from the small circuit board connected to the motherboard by the red and black wires.
  18. Maylong MN-1000P Keyboard Replacement: 18 단계, 이미지 1/1
    • Remove the two small black speakers on the corners connected to the motherboard by the black and red wires.
  19. Maylong MN-1000P Keyboard Replacement: 19 단계, 이미지 1/1
    • Disconnect the black connectors from the motherboard by pulling on the white ribbon cable.
  20. Maylong MN-1000P Keyboard Replacement: 20 단계, 이미지 1/2 Maylong MN-1000P Keyboard Replacement: 20 단계, 이미지 2/2
    • Remove the black covered wire connected to the motherboard by pulling the white ribbon cable away from the motherboard.
  21. Maylong MN-1000P Keyboard Replacement: 21 단계, 이미지 1/1
    • Using a spudger, remove the gold cylinder out of the indent at the bottom of the computer.
  22. Maylong MN-1000P Keyboard Replacement: 22 단계, 이미지 1/2 Maylong MN-1000P Keyboard Replacement: 22 단계, 이미지 2/2
    • Lift the motherboard up.
    • Remove the motherboard by detaching the clear tape from underneath the motherboard.
  23. Maylong MN-1000P Keyboard Replacement, Keyboard: 23 단계, 이미지 1/1
    • Hold the keyboard panel with the back facing you.
    • Using your thumbs, push on the silver squares.
  24. Maylong MN-1000P Keyboard Replacement: 24 단계, 이미지 1/2 Maylong MN-1000P Keyboard Replacement: 24 단계, 이미지 2/2
    • Flip the netbook over so the keyboard is facing upwards.
    • Insert a spudger between the keyboard and the top of the plate.
    • Lift the keyboard up and away from the mouse pad to remove.
결론
katelyn buckman
회원 가입일: 01/13/20
553 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 52
