소개
It can be a very stressful situation when your washing machine stops spinning. One option is to call an appliance expert, but this often involves spending excessive money on labor. Instead, this easy to follow guide will go over the steps required to replace the drive belt in your Maytag Bravos washer. It is a fairly quick fix taking only around 20 minutes to complete once the tools required (listed in the tools section) are obtained. Visuals are also provided to help ensure those of any skill level can perform this fix.
필요한 것
Disconnect the power supply from your Maytag Bravos washer. Following this, pull the device approximately 2 feet away from the wall.
To replace your drive belt in your Maytag Bravos washer follow this simple 8 step guide.
다른 3명이 해당 안내서를 완성하였습니다.
