주요 콘텐츠로 건너뛰기
Maytag Bravos Drive Belt Replacement
필요한 것
  1. Maytag Bravos Drive Belt Replacement, Drive Belt: 1 단계, 이미지 1/1
    • Disconnect the power supply from your Maytag Bravos washer. Following this, pull the device approximately 2 feet away from the wall.
  2. Maytag Bravos Drive Belt Replacement: 2 단계, 이미지 1/2 Maytag Bravos Drive Belt Replacement: 2 단계, 이미지 2/2
    • This step may be easier with two people.
    • Gently rest the washing machine against a wall or hard surface to keep it slightly elevated. This is important as you will need access to the underside of the machine for the following step.
  3. Maytag Bravos Drive Belt Replacement: 3 단계, 이미지 1/1
    • Have your 1/4-inch drive ratchet ready for the following step.
  4. Maytag Bravos Drive Belt Replacement: 4 단계, 이미지 1/2 Maytag Bravos Drive Belt Replacement: 4 단계, 이미지 2/2
    • Have someone carefully watch over the washing machine and make sure it is firmly rested against the wall to prevent injury.
    • Under the washing machine you will see a plastic cover over the drive belt. To remove this use your 1/4" drive ratchet.
  5. Maytag Bravos Drive Belt Replacement: 5 단계, 이미지 1/1
    • Following the removal of the cover, place the bolts inside the cover and place to the side somewhere safe.
  6. Maytag Bravos Drive Belt Replacement: 6 단계, 이미지 1/1
    • Following removal of the cover you will see the drive belt roped around two cogs.
    • The belt is fairly elastic and easy to remove. Remove the drive belt gently and replace with the new belt.
  7. Maytag Bravos Drive Belt Replacement: 7 단계, 이미지 1/1
    • Reattach the drive belt cover using your 1/4" drive ratchet.
  8. Maytag Bravos Drive Belt Replacement: 8 단계, 이미지 1/2 Maytag Bravos Drive Belt Replacement: 8 단계, 이미지 2/2
    • Gently rest the washing machine back against the wall and reconnect all power supply.
결론
To replace your drive belt in your Maytag Bravos washer follow this simple 8 step guide.
다른 3명이 해당 안내서를 완성하였습니다.
Reilly Farr
회원 가입일: 02/02/20
259 평판
안내서 1개 작성함
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020 회원
USFSM-STEWART-S20S1G1
23 회원들
안내서 27개 작성하였습니다
댓글 2개
What’s the trick of getting the new belt on the wheels?
palmer910 - 답글
Where can I find a drive belt for a Maytag Bravos MVWB750WQ0??? I have looked and looked online, and cannot find a source!
J Lipson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 55
30일 전: 275
전체 시간: 17,437
