이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Disconnect the power supply from your Maytag Bravos washer. Following this, pull the device approximately 2 feet away from the wall.
Gently rest the washing machine against a wall or hard surface to keep it slightly elevated. This is important as you will need access to the underside of the machine for the following step.
Under the washing machine you will see a plastic cover over the drive belt. To remove this use your 1/4" drive ratchet.
Following the removal of the cover, place the bolts inside the cover and place to the side somewhere safe.
Following removal of the cover you will see the drive belt roped around two cogs.
The belt is fairly elastic and easy to remove. Remove the drive belt gently and replace with the new belt.
Gently rest the washing machine back against the wall and reconnect all power supply.
다른 3명이 해당 안내서를 완성하였습니다.
