주요 콘텐츠로 건너뛰기
Maytag MVWX655DW1 Washer Basket Hub Replacement
필요한 것
  1. Maytag MVWX655DW1 Washer Basket Hub Replacement, Washer Basket Hub: 1 단계, 이미지 1/1
    • Use a 1/4-in Flathead screwdriver to remove the three 5mm screws behind the washing machine.
  2. Maytag MVWX655DW1 Washer Basket Hub Replacement: 2 단계, 이미지 1/3 Maytag MVWX655DW1 Washer Basket Hub Replacement: 2 단계, 이미지 2/3 Maytag MVWX655DW1 Washer Basket Hub Replacement: 2 단계, 이미지 3/3
    • Tape the lid down so it does not open when removing.
    • Pull the lid forward with your thumbs while pushing against the washer with your fingers.
    • Lift the lid up and place on the slots located where you removed the screws from the back.
  3. Maytag MVWX655DW1 Washer Basket Hub Replacement: 3 단계, 이미지 1/3 Maytag MVWX655DW1 Washer Basket Hub Replacement: 3 단계, 이미지 2/3 Maytag MVWX655DW1 Washer Basket Hub Replacement: 3 단계, 이미지 3/3
    • Remove the cap from the agitator with your flat head screwdriver. It should pop right off.
    • Using your 7/16 socket, unscrew the bolt attaching the agitator to the motor shaft.
  4. Maytag MVWX655DW1 Washer Basket Hub Replacement: 4 단계, 이미지 1/3 Maytag MVWX655DW1 Washer Basket Hub Replacement: 4 단계, 이미지 2/3 Maytag MVWX655DW1 Washer Basket Hub Replacement: 4 단계, 이미지 3/3
    • Lift up on the agitator and it should slide off the motor shaft exposing the washer hub underneath.
    • If it is stuck, put bolt back in halfway. Tap the bolt with a hammer while pulling up on the agitator to jog it loose.
  5. Maytag MVWX655DW1 Washer Basket Hub Replacement: 5 단계, 이미지 1/3 Maytag MVWX655DW1 Washer Basket Hub Replacement: 5 단계, 이미지 2/3 Maytag MVWX655DW1 Washer Basket Hub Replacement: 5 단계, 이미지 3/3
    • Use your Phillips #3 screwdriver to pull the retaining slip out.
    • Unscrew the six screws with the same Phillips #3 screwdriver to remove the hub.
  6. Maytag MVWX655DW1 Washer Basket Hub Replacement: 6 단계, 이미지 1/2 Maytag MVWX655DW1 Washer Basket Hub Replacement: 6 단계, 이미지 2/2
    • Take the new hub and slide it over the motor shaft.
    • Align the holes by only slightly screwing in each screw and turning the hub until all holes are aligned and screws are in.
    • Tighten all screws and then put new retaining clip into hub.
결론
Kyle
회원 가입일: 02/18/21
133 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 57
30일 전: 250
전체 시간: 8,682
