주요 콘텐츠로 건너뛰기
Mazda 323 BG Dashboard Replacement
필요한 것
  1. Mazda 323 BG Dashboard Replacement, Mazda 323 BG Dashboard Replacement: 1 단계, 이미지 1/1
    • Upgrading your Dashboard or what ever, you might want to open your Dashboard, this is the Easy Way...
  2. Mazda 323 BG Dashboard Replacement: 2 단계, 이미지 1/3 Mazda 323 BG Dashboard Replacement: 2 단계, 이미지 2/3 Mazda 323 BG Dashboard Replacement: 2 단계, 이미지 3/3
    • Open your door, you will see a Plastic Cover, remove it with a screwdriver or by hand.
  3. Mazda 323 BG Dashboard Replacement: 3 단계, 이미지 1/3 Mazda 323 BG Dashboard Replacement: 3 단계, 이미지 2/3 Mazda 323 BG Dashboard Replacement: 3 단계, 이미지 3/3
    • Remove the 3 screws holding the cover in place.
  4. Mazda 323 BG Dashboard Replacement: 4 단계, 이미지 1/1
    • Remove the 2 screws above of the Dashboard.
  5. Mazda 323 BG Dashboard Replacement: 5 단계, 이미지 1/1
    • Now to the magic: usualy, one must remove the steering wheel in order to continue. There are 2 easy alternatives:
  6. Mazda 323 BG Dashboard Replacement: 6 단계, 이미지 1/1
    • Option 1: With height adjustable steering wheel: remove the screw holding the top steering column trim and lower the column to its lowest by releasing the lever. Remove the top steering column trim.
  7. Mazda 323 BG Dashboard Replacement: 7 단계, 이미지 1/2 Mazda 323 BG Dashboard Replacement: 7 단계, 이미지 2/2
    • Option 2: Without height adjustable steering column: Remove all 4 screws of the steering column trim. Afterwards: remove the large golden screws. Be carefull whilst removing the last one: hold the column tight with one hand or it will fall, since it is screwed to nothing else.
  8. Mazda 323 BG Dashboard Replacement: 8 단계, 이미지 1/1
    • After Option 1 or 2: Pull the trim out of its holding clips. Disconnect all wires, except for clock and hazard switch. Slowly remove the trim, in case of Option 1: you might have to slightly bend the trim, be carefull. Afterwards: Rotate the trim 180° around the clock wire.
  9. Mazda 323 BG Dashboard Replacement: 9 단계, 이미지 1/1
    • Finally: Remove the 4 screws holding the dashboard. Disconnect the 3 connectors and speed wire and you are done!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Frank
회원 가입일: 12/21/17
196 평판
안내서 1개 작성함
댓글 한 개
That’s not the dashboard that’s a cluster removal
Matthew Canavan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 17
30일 전: 57
전체 시간: 5,760
