주요 콘텐츠로 건너뛰기
Maze Speed SSB-508 Battery Port Replacement
필요한 것
  1. Maze Speed SSB-508 Battery Port Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 Maze Speed SSB-508 Battery Port Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 Maze Speed SSB-508 Battery Port Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
    • Remove the back cover by inserting the plastic opening tool at the bottom left corner of the device.
  2. Maze Speed SSB-508 Battery Port Replacement: 2 단계, 이미지 2개 중 1개 Maze Speed SSB-508 Battery Port Replacement: 2 단계, 이미지 2개 중 2개
    • Remove fifteen 2mm Phillips #00 screws.
  3. Maze Speed SSB-508 Battery Port Replacement: 3 단계, 이미지 3개 중 1개 Maze Speed SSB-508 Battery Port Replacement: 3 단계, 이미지 3개 중 2개 Maze Speed SSB-508 Battery Port Replacement: 3 단계, 이미지 3개 중 3개
    • Lift the plastic opening tool up at the bottom left corner to create the gap.
    • Repeat this through all corners to remove the internal casing.
  4. Maze Speed SSB-508 Battery Port Replacement: 4 단계, 이미지 3개 중 1개 Maze Speed SSB-508 Battery Port Replacement: 4 단계, 이미지 3개 중 2개 Maze Speed SSB-508 Battery Port Replacement: 4 단계, 이미지 3개 중 3개
    • Unscrew the 2mm screw at the bottom right of the motherboard.
    • Remove the internal antenna casing from the motherboard.
  5. Maze Speed SSB-508 Battery Port Replacement: 5 단계, 이미지 2개 중 1개 Maze Speed SSB-508 Battery Port Replacement: 5 단계, 이미지 2개 중 2개
    • Unplug the speaker at the top of the motherboard.
  6. Maze Speed SSB-508 Battery Port Replacement: 6 단계, 이미지 2개 중 1개 Maze Speed SSB-508 Battery Port Replacement: 6 단계, 이미지 2개 중 2개
    • Desolder the gold ribbon that is connected to the motherboard at the bottom left corner.
  7. Maze Speed SSB-508 Battery Port Replacement: 7 단계, 이미지 3개 중 1개 Maze Speed SSB-508 Battery Port Replacement: 7 단계, 이미지 3개 중 2개 Maze Speed SSB-508 Battery Port Replacement: 7 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to remove cable from the ZIF connectors located at the bottom left of the motherboard.
    • Use the tweezers to remove the second cable from ZIF connector located to the right of the speaker that you unplugged in step five.
    • ZIF connector stands for Zero Insertion Force. Flip the small locking tap before removing the cable.
  8. Maze Speed SSB-508 Battery Port Replacement: 8 단계, 이미지 2개 중 1개 Maze Speed SSB-508 Battery Port Replacement: 8 단계, 이미지 2개 중 2개
    • At this point, the motherboard should be able to be lifted up from the bottom.
    • Use the tweezers to dislodge the speaker.
    • After the speaker is dislodged, flip the motherboard up so that you can see the cable.
    • Using a soldering tool, desolder the cable from the back of the motherboard.
  9. Maze Speed SSB-508 Battery Port Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the motherboard from the back.
  10. Maze Speed SSB-508 Battery Port Replacement, Battery Port: 10 단계, 이미지 3개 중 1개 Maze Speed SSB-508 Battery Port Replacement, Battery Port: 10 단계, 이미지 3개 중 2개 Maze Speed SSB-508 Battery Port Replacement, Battery Port: 10 단계, 이미지 3개 중 3개
    • Flip the motherboard upside down and you will see the battery port connected to the motherboard with 5 different soldered places.
    • Use the pliers to hold the motherboard and desolder the 5 places which are connected to the motherboard.
  11. Maze Speed SSB-508 Battery Port Replacement: 11 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use the tweezers to pull out the battery port.
    • Then, replace it with the new battery port.
결론
작성자
8다른 기여자 명과 함께
Jun Soo Kim
회원 가입일: 07/08/19
385 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 2
지난 30일: 21
전체 시간: 1,540
