주요 콘텐츠로 건너뛰기
Maze Speed SSB-508 Screen Replacement
필요한 것
  1. Maze Speed SSB-508 Screen Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 Maze Speed SSB-508 Screen Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 Maze Speed SSB-508 Screen Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
    • Remove the back cover by inserting the plastic opening tool at the bottom left corner of the device.
  2. Maze Speed SSB-508 Screen Replacement: 2 단계, 이미지 2개 중 1개 Maze Speed SSB-508 Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Remove fifteen 2mm Phillips #00 screws.
  3. Maze Speed SSB-508 Screen Replacement: 3 단계, 이미지 3개 중 1개 Maze Speed SSB-508 Screen Replacement: 3 단계, 이미지 3개 중 2개 Maze Speed SSB-508 Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Lift the plastic opening tool up at the bottom left corner to create the gap.
    • Repeat this through all corners to remove the internal casing.
  4. Maze Speed SSB-508 Screen Replacement: 4 단계, 이미지 3개 중 1개 Maze Speed SSB-508 Screen Replacement: 4 단계, 이미지 3개 중 2개 Maze Speed SSB-508 Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Unscrew the 2mm screw at the bottom right of the motherboard.
    • Remove the internal antenna casing from the motherboard.
  5. Maze Speed SSB-508 Screen Replacement: 5 단계, 이미지 2개 중 1개 Maze Speed SSB-508 Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Unplug the speaker at the top of the motherboard.
  6. Maze Speed SSB-508 Screen Replacement: 6 단계, 이미지 2개 중 1개 Maze Speed SSB-508 Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Desolder the gold ribbon that is connected to the motherboard at the bottom left corner.
  7. Maze Speed SSB-508 Screen Replacement: 7 단계, 이미지 3개 중 1개 Maze Speed SSB-508 Screen Replacement: 7 단계, 이미지 3개 중 2개 Maze Speed SSB-508 Screen Replacement: 7 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to remove cable from the ZIF connectors located at the bottom left of the motherboard.
    • Use the tweezers to remove the second cable from ZIF connector located to the right of the speaker that you unplugged in step five.
    • ZIF connector stands for Zero Insertion Force. Flip the small locking tap before removing the cable.
  8. Maze Speed SSB-508 Screen Replacement: 8 단계, 이미지 2개 중 1개 Maze Speed SSB-508 Screen Replacement: 8 단계, 이미지 2개 중 2개
    • At this point, the motherboard should be able to be lifted up from the bottom.
    • Use the tweezers to dislodge the speaker.
    • After the speaker is dislodged, flip the motherboard up so that you can see the cable.
    • Using a soldering tool, desolder the cable from the back of the motherboard.
  9. Maze Speed SSB-508 Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the motherboard from the back.
  10. Maze Speed SSB-508 Screen Replacement, Screen: 10 단계, 이미지 2개 중 1개 Maze Speed SSB-508 Screen Replacement, Screen: 10 단계, 이미지 2개 중 2개
    • Apply the heated iOpener to all sides of the screen (left, right, top, and bottom) for 90 seconds (or more if necessary) to soften the adhesive.
  11. Maze Speed SSB-508 Screen Replacement: 11 단계, 이미지 3개 중 1개 Maze Speed SSB-508 Screen Replacement: 11 단계, 이미지 3개 중 2개 Maze Speed SSB-508 Screen Replacement: 11 단계, 이미지 3개 중 3개
    • Use a Jimmy's flexible steel blade to separate the screen from the frame. Insert the blade between the frame and screen then carefully lift using the blade.
    • Gently lift the glass screen and remove from the frame.
  12. Maze Speed SSB-508 Screen Replacement: 12 단계, 이미지 3개 중 1개 Maze Speed SSB-508 Screen Replacement: 12 단계, 이미지 3개 중 2개 Maze Speed SSB-508 Screen Replacement: 12 단계, 이미지 3개 중 3개
    • There will be a thin flat cable at the top of the screen in which you need to carefully peel back.
  13. Maze Speed SSB-508 Screen Replacement: 13 단계, 이미지 1개 중 1개
    • Move the connecting wire through the hole at the top frame.
    • Then, remove the glass screen and replace with the new one.
결론
To reassemble your device, follow these instructions carefully in reverse order.
작성자
9다른 기여자 명과 함께
Jun Soo Kim
회원 가입일: 07/08/19
385 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 13
전체 시간: 1,152
