주요 콘텐츠로 건너뛰기
Maze Speed SSB-508 Speaker and Microphone Replacement
필요한 것
  1. Maze Speed SSB-508 Speaker and Microphone Replacement, Speaker and Microphone: 1 단계, 이미지 3개 중 1개 Maze Speed SSB-508 Speaker and Microphone Replacement, Speaker and Microphone: 1 단계, 이미지 3개 중 2개 Maze Speed SSB-508 Speaker and Microphone Replacement, Speaker and Microphone: 1 단계, 이미지 3개 중 3개
    • With the phone face down, remove the back cover with the plastic opening tool. For easiest access, insert the plastic opening tool in the bottom left corner.
  2. Maze Speed SSB-508 Speaker and Microphone Replacement: 2 단계, 이미지 1개 중 1개
    • After the back cover is removed, remove the battery, sim cards, and micro SD card. These components are highlighted in red.
  3. Maze Speed SSB-508 Speaker and Microphone Replacement: 3 단계, 이미지 3개 중 1개 Maze Speed SSB-508 Speaker and Microphone Replacement: 3 단계, 이미지 3개 중 2개 Maze Speed SSB-508 Speaker and Microphone Replacement: 3 단계, 이미지 3개 중 3개
    • Using the screwdriver, remove fourteen 2mm screws to access the internal casing of the phone.
    • After the screws are removed, use the plastic opening tool to remove the internal casing cover.
  4. Maze Speed SSB-508 Speaker and Microphone Replacement: 4 단계, 이미지 2개 중 1개 Maze Speed SSB-508 Speaker and Microphone Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Locate the wire that attaches the motherboard to the daughter-board of the speaker and mic. Using tweezers, disconnect the wire from the motherboard.
  5. Maze Speed SSB-508 Speaker and Microphone Replacement: 5 단계, 이미지 3개 중 1개 Maze Speed SSB-508 Speaker and Microphone Replacement: 5 단계, 이미지 3개 중 2개 Maze Speed SSB-508 Speaker and Microphone Replacement: 5 단계, 이미지 3개 중 3개
    • Using your soldering tools, un-solder both set of wires that are connected to the daughter-board.
    • You may now replace the old speaker and mic with new accessories.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Bryce Stewart
회원 가입일: 07/09/19
142 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 936
