소개
This guide will provide instructions for removing the speaker and mic in a Maze Speed phone. You will need a plastic opening tool, screwdriver, tweezers and soldering equipment. You should know how to solder to avoid damaging other components in the phone.
필요한 것
With the phone face down, remove the back cover with the plastic opening tool. For easiest access, insert the plastic opening tool in the bottom left corner.
다른 2명이 해당 안내서를 완성하였습니다.
