주요 콘텐츠로 건너뛰기
Measuring Current with Clamp Meter and AC Line Splitter
필요한 것
  1. Measuring Current with Clamp Meter and AC Line Splitter, Measuring Current with Clamp Meter and AC Line Splitter: 1 단계, 이미지 3개 중 1개 Measuring Current with Clamp Meter and AC Line Splitter, Measuring Current with Clamp Meter and AC Line Splitter: 1 단계, 이미지 3개 중 2개 Measuring Current with Clamp Meter and AC Line Splitter, Measuring Current with Clamp Meter and AC Line Splitter: 1 단계, 이미지 3개 중 3개
    • Connect AC Line Splitter to power Source.
    • Connect device to test to AC line splitter.
    • On Multimeter, select AC Current.
  2. Measuring Current with Clamp Meter and AC Line Splitter: 2 단계, 이미지 2개 중 1개 Measuring Current with Clamp Meter and AC Line Splitter: 2 단계, 이미지 2개 중 2개
    • Clamp meter on the x1 loop of the line splitter for most devices. Only use the x10 loop if you are testing a very low current device.
    • Turn on the device you are testing.
    • Read the current indicated on your meter.
    • You are done with this procedure. Turn off the device you are testing and disconnect your equipment.
결론
Using this process can allow you to measure how much current a device is drawing which can aid in troubleshooting. A device drawing more than it's rated amount of current can be an indication of a problem.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
rickwag
회원 가입일: 10/18/10
1,602 평판
안내서 13개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 17
전체 시간: 140
