주요 콘텐츠로 건너뛰기
Megawheels S10 Rear Mudguard Replacement
필요한 것
  1. Megawheels S10 Rear Mudguard Replacement, Rear Mudguard: 1 단계, 이미지 1/1
    • Hold down the power button and wait for a beep to ensure that the scooter is turned off.
  2. Megawheels S10 Rear Mudguard Replacement: 2 단계, 이미지 1/1
    • Put up the kickstand so that the scooter is upright.
  3. Megawheels S10 Rear Mudguard Replacement: 3 단계, 이미지 1/1
    • Unscrew the old mudguard.
  4. Megawheels S10 Rear Mudguard Replacement: 4 단계, 이미지 1/1
    • Grip the wheel and pull off the mudguard.
  5. Megawheels S10 Rear Mudguard Replacement: 5 단계, 이미지 1/1
    • Remove the connector.
  6. Megawheels S10 Rear Mudguard Replacement: 6 단계, 이미지 1/1
    • Attach the new mudguard's power connector.
  7. Megawheels S10 Rear Mudguard Replacement: 7 단계, 이미지 1/1
    • Line up the new mudguard with the screw holes and reinsert the screws.
결론
If these steps are followed correctly, then your manual break and tail light should function good as new!
Andrew DiCapo
회원 가입일: 09/28/21
145 평판
안내서 1개 작성함
University of North Texas, Team 2-9, Raign Fall 2021 University of North Texas, Team 2-9, Raign Fall 2021 회원
UNT-RAIGN-F21S2G9
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 47
전체 시간: 1,217
