Löse den Schlauch zwischen oberem Kolben und Kaffeeauslauf.
Entferne den oberen Kolben.
Schraube die Torx T20 Schraube aus dem Sieb des oberen Kolbens heraus.
Entnimm Dichtungshalter und Dichtung.
Tausche die Dichtungen am oberen Kolben, am Kaffeeauslauf und an der Wasserzufuhr aus.
Reinige alle Teile gut. Gib ein bisschen lebensmittelechtes Silikon auf die Dichtflächen.
Drehe die beiden Schrauben heraus. Hebe das Ventil ab. Prüfe und reinige es.
Hinweis: am unteren Kolbenschaft befindet sich auch noch eine Dichtung, die allerdings etwas schwieriger zu ersetzen ist.
Fette alle gleitenden Teile leicht mit lebensmittelechtem Silikon und baue alles wieder zusammen. Prüfe auf Leichtgängigkeit.
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
다른 11명이 해당 안내서를 완성하였습니다.
댓글 2개
The brewing unit in my Melitta Avanza Series 600 (which is apparently identical) was completely stuck inside the machine, and the only way I could get it out was to follow this guide. Unscrewing the accessible side of the brewing unit gave me the necessary access to finally get the brewing unit unstuck and out of the machine. The cap mentioned in step 2 was a bit hard to get out with the brewing unit still inside the machine, but by first unscrewing all the other screws to loosen the side a bit and then using some force, I finally got it off without breaking it.
Note that I also had to reset the main gear position to get the brewing unit back into the machine, which on my machine was performed by pressing the single + double espresso front panel buttons for 2 seconds.
The reason why it was stuck? 100% my fault. I turned the machine off in the middle of a cleaning cycle when I realised I forgot to insert a cleaning tablet, and then tried to get the brewing unit out and ... yeah ... don't be an idiot like I was, do NOT attempt to take the brewing unit out while it's in "engaged" mode, unless you too wish to follow this guide for that reason. 😉
Fixiepixer - 답글
There is also a more bloodless way: open the left side, find the cables to the motor. Connect 12 V DC, et voila....
VauWeh -
