소개
You have to replace the heater if the coffee is too cold or the flow is - mostly disturbed by limescale.
필요한 것
Remove the water tank and drainage tray.
Remove the side cover and remove the brewing unit.
Remove all coffee beans.
Press carefully into the slits on the sides using a minus screwdriver or a flat metal spatula, to release the clasps on the upper surface. These may be well tight and you have to use some force.
You should have created a separation between the upper surface and side panels. Now lever the upper covering away using a plastic tool. This may be quite stuck and you may apply some force.
Repeat the steps in reverse order to reassemble your device.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 2개
Sehr schöne Anleitung! Stehe gerade vor der selben Maschine und prüfe gerade warum kein Wasser herauskommt.
Schläuche wurden geprüft, Flowmeter geprüft, ist alles freigängig. Pumpe drückt Wasser bis zum Erhitzer. Ich denke dieser ist verkalkt.
Schöne Anleitung, enthält alles was man braucht!
Zum Prüfen einfach reinblasen. Muss ziemlich leicht gehen.
VauWeh -
