주요 콘텐츠로 건너뛰기
Memorex 2Xtreme MP3830-01 CD Cover Latch Replacement
필요한 것
  1. Memorex 2Xtreme MP3830-01 CD Cover Latch Replacement, CD Cover Latch: 1 단계, 이미지 1/1
    • Open the CD cover so that the latch can be accessed.
  2. Memorex 2Xtreme MP3830-01 CD Cover Latch Replacement: 2 단계, 이미지 1/1
    • Using a 3/16" flat head screwdriver, gently pry in the corner of the latch and the boombox housing.
    • You should see the latch pop out of the housing a little bit.
    • Then move to the opposite side of the latch and gently pry there.
    • Keep moving back and forth until the latch comes loose and can be removed with your fingers.
  3. Memorex 2Xtreme MP3830-01 CD Cover Latch Replacement: 3 단계, 이미지 1/1
    • When the latch is removed, it should like the part in the picture.
결론
Meghan
회원 가입일: 10/16/14
579 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 2-4, Duarte Fall 2014 UMass Dartmouth, Team 2-4, Duarte Fall 2014 회원
UMASSD-DUARTE-F14S2G4
4 회원들
안내서 6개 작성하였습니다
댓글 2개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 23
전체 시간: 2,227
