주요 콘텐츠로 건너뛰기
Memorex CD Alarm Clock Radio CD Lid Spring Replacement
필요한 것
  1. Memorex CD Alarm Clock Radio CD Lid Spring Replacement, Memorex CD Alarm Clock Radio: 1 단계, 이미지 1/3 Memorex CD Alarm Clock Radio CD Lid Spring Replacement, Memorex CD Alarm Clock Radio: 1 단계, 이미지 2/3 Memorex CD Alarm Clock Radio CD Lid Spring Replacement, Memorex CD Alarm Clock Radio: 1 단계, 이미지 3/3
    • Turn the clock radio over so the bottom is facing up.
    • Pull the tab upward and remove the cover from the battery compartment.
    • Remove the batteries.
  2. Memorex CD Alarm Clock Radio CD Lid Spring Replacement: 2 단계, 이미지 1/3 Memorex CD Alarm Clock Radio CD Lid Spring Replacement: 2 단계, 이미지 2/3 Memorex CD Alarm Clock Radio CD Lid Spring Replacement: 2 단계, 이미지 3/3
    • Remove the five screws on the bottom of the device with a screwdriver.
    • Grasp the top and bottom and gently pull apart.
  3. Memorex CD Alarm Clock Radio CD Lid Spring Replacement, CD Lid Spring: 3 단계, 이미지 1/2 Memorex CD Alarm Clock Radio CD Lid Spring Replacement, CD Lid Spring: 3 단계, 이미지 2/2
    • Locate the spring and the spring's retaining piece.
    • There will be a screw that holds the retaining piece in place.
    • Use a screwdriver to remove the screw and the retaining piece.
  4. Memorex CD Alarm Clock Radio CD Lid Spring Replacement: 4 단계, 이미지 1/2 Memorex CD Alarm Clock Radio CD Lid Spring Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Grasp and remove the spring using tweezers.
결론
Aubrey Frank
회원 가입일: 02/15/18
399 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 336
