소개
Removing the PCB board requires a Phillips #1 screwdriver with at least a 15 cm shaft and a set of tweezers. Make sure there are no batteries in the device and that it is not plugged in before starting the procedure.
필요한 것
Turn the clock radio over so the bottom is facing up.
Pull the tab upward and remove the cover from the battery compartment.
Remove the batteries.
Remove the (5) 7mm screws with a Phillips #1 screwdriver and a pair of tweezers.
거의 끝나갑니다!
결론
