이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If the Minimove is not turning on when new batteries are used, the battery wires may have come loose or disconnected. With this guide, you will replace the battery wires for the Minimove by soldering. For more information on soldering reference the iFixit soldering guide.
필요한 것
Remove the two plastic screw covers on the back of your Minimove by inserting the flat end of your plastic opening tool between the screw cover and the back panel and prying it out.
Remove the bottom panel of the boombox by carefully pulling the panel straight backwards from the boombox until the motherboard and daughterboard are free.
다른 3명이 해당 안내서를 완성하였습니다.
