소개
Comment accéder au menu des services pour tous les smartphones Sony XPERIA et la tablette 3G. Tutoriel vidéo :
동영상 개요
Tapez le code suivant sur le clavier : *#*#7378423#*#*.
Vous pouvez choisir entre :
- Information du service
- Paramètres du service
- Tests du service
- Calibrage
- Paramètres de personnalisation
다른 78명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 229개
hi Kerel,
you dont have to dial that number.
Just type on your phone, when u enter last star symbol itself the options will display !
Yup, I also tried it on a Sony V3+ and nothing happened.
J'ai un téléphone sony xperia ST26i ont expérimenté plusieurs solutions pour ouvrir l'écran, mais en vain
I can't even get into service menu
I gave the no but I could not get into service menu
farzi -
just got xperia c4 dual sim, water damage and the touch pannel not working. work on touchscreen connector a little bit with soldering iron+hot air, now touch pannel works perfectly. just need to make sure all all touch pannel surface are works. using your code for testing, done. thank you for the code
I dial the code and nothing appear
Para el xperia x f5121 tambien sirve?
My phone setting in not work
Plz help me
I have forgotten my private opening code how to enter
ivar.norby - 답글
thanks for this excellent post, i’ve written something similar here > Sony Xperia Secret Codes
sony sp 5303
come faccio a cambiare imei
il mio phone e il seguente xperia L1
Ich habe ein gut erhaltenes xperia z5 premium gekauft.
Kann ich irgendwie die Gesamtlaufzeit ermitteln.
Ich meine eine Zahl, die nicht durch Reset wieder auf 0 gesetzt wird sondern die die Laufzeit seit dem ersten Booten anzeigt?
unable to unlock screen lock on VODAPHONE Sony XPERIA D2203 forgot my pin no star or hash facility on screen lock. looking for a code to open as there is no program to access phone
code is not working to my zony xperia xz2 phone.solution please..
I just tried this on a Sony V3+ phone and nothing happened
Ahmad Dan-Hamidu - 답글
Sony Xperia z3 compact does not show calibration.
M and R Johns - 답글
Did nothing for my pale screen with vertical white bars appering
kevinbuk - 답글
Hallo, bei mir öffnet sich das Service Menü nur mit drei Funktionen. Calibration und Customization Settings fehlen. Habe das Z5 gebraucht gekauft. Wie komme ich an die anderen Funktionen. Muss das Gerät zurücksetzten da es ständig neu startet. Danke
Jeppitsme - 답글
was bedeuten all die Einträge im einzelnen? Wie löse ich damit den Raketenstart aus?
ein Stein - 답글
I have sony xperia x performance and it worked
Maleesha Priyanjana - 답글
