주요 콘텐츠로 건너뛰기
Mercedes W123 disable security alarm
  1. Mercedes W123  disable security alarm, Remove floormats: 1 단계, 이미지 1개 중 1개
    • Remove passenger (right) floor mat(s). Mine had the sound deadening one plus a protective one over the top of that.
  2. Mercedes W123  disable security alarm, Remove plastic kick plate from right footwell area.: 2 단계, 이미지 2개 중 1개 Mercedes W123  disable security alarm, Remove plastic kick plate from right footwell area.: 2 단계, 이미지 2개 중 2개
    • Remove passenger side (right) plastic kick plate. You must move it up to disengage the metal hooks in the car body from the plastic kick plate clip points (one lower, two upper). Tilt the panel counter-clockwise and remove toward rear of vehicle. Takes a bit of patience to manuever it effectively to tilt backward and free from footwell area.
  3. Mercedes W123  disable security alarm, Disconnect security alarm relay: 3 단계, 이미지 2개 중 1개 Mercedes W123  disable security alarm, Disconnect security alarm relay: 3 단계, 이미지 2개 중 2개
    • Disconnect battery ground strap. You might be able to skip this step if you are confident and careful not to do amatuer arc welding of potentially hot wires in these harness plugs. I got by without doing this step your mileage and skill may vary.
    • Disconnect the two multi plugs from the alarm relay. These are fairly stubborn to disconnect. Requires a bit of pressure to remove.
    • I apologize for the fuzzy photo of the wiring harness but I was not able to get a clear shot. The second shot is a closeup of the relay after it is physically removed. I took that step because I don't want this thing annoying me while trying to drive the vehicle ever again.
    • The relay is attached to the kick panel with typical plastic movable core rivets. You can push the core out with any handy tool (I used a pocket knife blade). Mine had only one but hey this is a 31 year old car!!!
    • If you leave it attached to the kick plate you might want to tape over the harness ends somehow so they can't short against those exposed pins.
    • I understand later models of mercedes vehicles use the same relay but also have an additional relay in the dashboard that disables starting the engine. If you google you can probably find instructions for how to work around that "feature". I will not cover that here because I have no vehicle to provide photo context.
    • Reassemble kick plate being careful to make sure the harness is protected from shorting against anything.
    • Reinstall floor mat(s).
    • Reattach battery ground if you disconnected it for safety.
결론
Enjoy the sound of silence.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
tcagle53
회원 가입일: 06/18/14
8,595 평판
안내서 11개를 작성함
Chromebook Cowboys Chromebook Cowboys 회원
Community
4 회원들
안내서 27개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 12
지난 30일: 35
전체 시간: 4,380
