주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Removing the ash tray on a W123 is easy, but the method is not immediately obvious. This guide will show you how. Also, you'll learn how to remove the backing plate that the ash tray sits in in case you need to get greater access to the area behind it.
부품
지정된 부품이 없습니다.
  1. With the car turned off, engage the parking brake. Failure to do this could be dangerous as you need to move the gear lever out of park to continue this guide.
    • With the car turned off, engage the parking brake. Failure to do this could be dangerous as you need to move the gear lever out of park to continue this guide.
    • Then move the shift lever all the way back in to L to give you room to work.
  2. Now pull the ash tray open as you normally would.
    • Now pull the ash tray open as you normally would.
  3. Now push down on the tab that is at the center of the ash tray assembly.
    • Now push down on the tab that is at the center of the ash tray assembly.
  4. While continuing to hold down the tab you can pull the ash tray forward, and out of the opening it sits in.
    • While continuing to hold down the tab you can pull the ash tray forward, and out of the opening it sits in.
  5. If you want to remove the entire assembly including the bracket that the ash tray rests in you can proceed to remove the two screws that hold it to the center console.
    • If you want to remove the entire assembly including the bracket that the ash tray rests in you can proceed to remove the two screws that hold it to the center console.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Nicolas Siemsen
회원 가입일: 2013년 12월 06일
35,226 평판
안내서 79개 작성하였습니다
Master Techs Master Techs 회원
Community
296 회원들
안내서 980개 작성하였습니다
What would be the purpose of removing ashtray ?
Andrea Summadre - 답글
It provides access to the portion of the center console behind the ash tray. There is wiring back there. It can also help with the removal of the shift gate panel.
Nicolas Siemsen -
Removal of ashtray is also necessary to access the lamp which illuminates the cavity. After taking ashtray out, remove two Philips (+) screws, then separate metal cover from plastic housing. Next to the lighter housing is light socket. It holds a 12 volt, 2 watt, T2 bayonet base, #1272 lamp. Push, then twist lamp to remove. Clean copper terminal at side of socket as well as moving contact on side of ashtray housing. This lamp is same type as used for automatic shift indicator. This is one of the most overlooked lamps in a W123 chassis. Tip: while metal cover is removed, clean and scrub ashtray, it is much easier to access this way.
analogcd - 답글
Hello Nicolas, How about removing the radio, is there a latch to be released from the ash tray compartment?
chirolob - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 63
전체 시간: 9,312
