소개
There are many systems in your car that depend on a well-performing battery. Since modern batteries are sealed they are fairly low maintenance items. However, they should not be completely ignored. Learn to keep yours performing well.
필요한 것
The battery on diesel W123 cars is located in the far rear left corner of the engine bay, as you face it from the front of the car.
This battery is in fairly good shape, but has not been maintained in several years and has gotten dirty and could use some love...
To begin, disconnect the positive and negative battery terminals. This will be covered further in Step 3.
Use a crescent wrench to loosen the nuts on the battery terminals. Do not remove the nut fully, just loosen it enough to remove the terminal. On W123's, this nut is likely a 13mm.
Pull the terminals off, starting with the Negative "-" terminal, then the Positive "+" terminal.
Use a soft metal brush to clean any corrosion or dirt from the battery posts.
Then use some mild cleaner on a damp shop towel to wipe down the rest of the battery of dirt and corrosion.
If your battery is really dirty, and has lots of corrosion, consider purchasing a spray can of battery cleaner designed for heavier cleaning.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 3개
It might be helpful to add that the negative battery terminal should be removed first, and isolated. Disconnecting the positive terminal first could lead to a short (and sparks) if the wrench contacts another metal object. There is an old story of a left handed man who disconnected the positive first and the wrench touched his wedding ring. In short, he practically arc welded the wrench to his ring and burnt his finger badly.
Hi. Can the gas battery be maintained or the distilled water is increased or changed. And how so if the answer is yes
W 123 300d automático de 1976 , vibra un poco sobre todo cuando giras la dirección
