주요 콘텐츠로 건너뛰기
Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement
필요한 것
  1. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement, Tail/Reverse/Rear Turn Signal Bulb: 1 단계, 이미지 1/1
    • The access panel for all of these lights is on the inside of the trunk. There's one on each side. This guide will cover one side; simply repeat on the other to complete the job.
  2. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: 2 단계, 이미지 1/1
    • The panel is secured with two thumb screws. Remove these.
  3. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: 3 단계, 이미지 1/1
    • Pull the panel out and away from the back of the car, being careful not to force the bulbs out of the holes.
  4. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: 4 단계, 이미지 1/1
    • There are five bulbs in each tail light housing. They are as follows:
    • Brake light
    • Reverse light
    • Tail light
    • Turn signal
    • Side marker
  5. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: 5 단계, 이미지 1/1
    • To remove any of the bulbs simply turn them counter clockwise approximately a half turn and then pull them out of their socket.
  6. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: 6 단계, 이미지 1/3 Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: 6 단계, 이미지 2/3 Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: 6 단계, 이미지 3/3
    • Three of the bulbs are #1156
    • One is a #96
    • One is a small 4W blub
  7. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: 7 단계, 이미지 1/1
    • Before installing the new bulb consider cleaning the socket with a soft metal wire brush such as the brass brush shown to help remove any corrosion.
    • Then install the new bulb, reassemble the device, and finally, be sure to test that all of your rear lights are working before going for a drive.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Nicolas Siemsen
회원 가입일: 12/06/13
38,247 평판
안내서 79개 작성하였습니다
Master Techs Master Techs 회원
Community
311 회원들
안내서 1,194개 작성하였습니다
2 Comments
Very informative, descriptive and point on analysis.
George T Peeke - 답글
Und wie wird dies beim Kombi gemacht?
srossius - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 29
30일 전: 111
전체 시간: 11,017
