도구
  1. The access panel for all of these lights is on the inside of the trunk. There's one on each side. This guide will cover one side; simply repeat on the other to complete the job.
    • The access panel for all of these lights is on the inside of the trunk. There's one on each side. This guide will cover one side; simply repeat on the other to complete the job.
  2. The panel is secured with two thumb screws. Remove these.
    • The panel is secured with two thumb screws. Remove these.
  3. Pull the panel out and away from the back of the car, being careful not to force the bulbs out of the holes.
    • Pull the panel out and away from the back of the car, being careful not to force the bulbs out of the holes.
  4. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  5. There are five bulbs in each tail light housing. They are as follows:
    • There are five bulbs in each tail light housing. They are as follows:
    • Brake light
    • Reverse light
    • Tail light
    • Turn signal
    • Side marker
  6. To remove any of the bulbs simply turn them counter clockwise approximately a half turn and then pull them out of their socket.
    • To remove any of the bulbs simply turn them counter clockwise approximately a half turn and then pull them out of their socket.
  7. Three of the bulbs are #1156 One is a #96 One is a small 4W blub
    • Three of the bulbs are #1156
    • One is a #96
    • One is a small 4W blub
  8. Before installing the new bulb consider cleaning the socket with a soft metal wire brush such as the brass brush shown to help remove any corrosion.
    • Before installing the new bulb consider cleaning the socket with a soft metal wire brush such as the brass brush shown to help remove any corrosion.
    • Then install the new bulb, reassemble the device, and finally, be sure to test that all of your rear lights are working before going for a drive.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Nicolas Siemsen
회원 가입일: 2013년 12월 06일
30,996 평판
안내서 79개 작성하였습니다
Master Techs Master Techs 회원
Community
286 회원들
안내서 808개 작성하였습니다
Very informative, descriptive and point on analysis.
George T Peeke - 답글
Und wie wird dies beim Kombi gemacht?
srossius - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 60
전체 시간: 6,692
