이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
The access panel for all of these lights is on the inside of the trunk. There's one on each side. This guide will cover one side; simply repeat on the other to complete the job.
Pull the panel out and away from the back of the car, being careful not to force the bulbs out of the holes.
There are five bulbs in each tail light housing. They are as follows:
Brake light
Reverse light
Tail light
Turn signal
Side marker
To remove any of the bulbs simply turn them counter clockwise approximately a half turn and then pull them out of their socket.
Before installing the new bulb consider cleaning the socket with a soft metal wire brush such as the brass brush shown to help remove any corrosion.
Then install the new bulb, reassemble the device, and finally, be sure to test that all of your rear lights are working before going for a drive.
다른 10명이 해당 안내서를 완성하였습니다.
댓글 2개
Very informative, descriptive and point on analysis.
