주요 콘텐츠로 건너뛰기
Mercedes W123 Diesel Fuel Filter, Primary Replacement
필요한 것
  1. Mercedes W123 Diesel Fuel Filter, Primary Replacement, Fuel Filter, Primary: 1 단계, 이미지 1/1
    • Here is your clear fuel primary filter. It is located directly next to the fuel primer pump.
  2. Mercedes W123 Diesel Fuel Filter, Primary Replacement: 2 단계, 이미지 1/1
    • Begin by loosening this hose clamp, at the top of the primary filter, nearest the engine.
    • Pull the primary filter up and out of this hose. A small amount of fuel will leak out, consider putting a towel, plastic bag, or other appropriate catch underneath.
  3. Mercedes W123 Diesel Fuel Filter, Primary Replacement: 3 단계, 이미지 1/1
    • Now loosen the clamp on the bottom of the primary filter, further from the engine.
    • You will now be able to pull the filter out the rest of the way. The fuel in it will drain out, catch it with towel or something similar.
  4. Mercedes W123 Diesel Fuel Filter, Primary Replacement: 4 단계, 이미지 1/1
    • Here is the old primary filter, removed from the car. Note the large chunks of debris in the filter.
  5. Mercedes W123 Diesel Fuel Filter, Primary Replacement: 5 단계, 이미지 1/1
    • You can see here the new primary filter. Note that the filter is usually marked with an arrow noting the direction of fuel flow. It should be installed with this arrow pointing towards the engine.
  6. Mercedes W123 Diesel Fuel Filter, Primary Replacement: 6 단계, 이미지 1/1
    • Install the new filter by retracing the steps so far, just backwards.
    • This is a good time to consider replacing the large secondary filter. If you would like guidance on this, see the secondary fuel filter replacement guide.
    • Then, pump the primer pump on the car until the primary filter fills with fuel. It's normal for there to be a small air bubble in the primary filter but it should be mostly clear.
결론
When finished, run the engine to ensure it's been primed properly.
다른 13명이 해당 안내서를 완성하였습니다.
Nicolas Siemsen
회원 가입일: 12/06/13
38,695 평판
안내서 79개 작성하였습니다
Master Techs Master Techs 회원
Community
314 회원들
안내서 1,322개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 110
전체 시간: 16,241
