주요 콘텐츠로 건너뛰기
Mercedes W123 Door Sill Disassembly
  1. Mercedes W123 Door Sill Disassembly, Sills or trims can: 1 단계, 이미지 1/2 Mercedes W123 Door Sill Disassembly, Sills or trims can: 1 단계, 이미지 2/2
    • The steps are the same for the 4 doors and the pieces are under pressure. Likewise, time can cause them to get stuck, you must proceed with care.
    • First we will have to open the door, and locate one of the corners, in which a plastic tool is inserted, with which we will travel the length of the piece to release it, this without forcing the piece.
  2. Mercedes W123 Door Sill Disassembly: 2 단계, 이미지 1/2 Mercedes W123 Door Sill Disassembly: 2 단계, 이미지 2/2
    • Once the previous step is done, introduce a second plastic tool (it can be a screwdriver covered with tape) on the inside of the piece, it must be inserted as close to the center of it, this is the side where we will exert leverage to release the piece. of its fit.
    • Firmly exert force, but without violence, making sure the piece does not flex too much, remember that it is old plastic. If necessary, pry both tools, making sure they are as far inside as possible.
    • You can use your hands once you have managed to lift one of the sides.
  3. Mercedes W123 Door Sill Disassembly: 3 단계, 이미지 1/2 Mercedes W123 Door Sill Disassembly: 3 단계, 이미지 2/2
    • This is the bottom side of the piece, it is simply embedded on the metal edge of the pressure door, and to place them simply position and press
결론
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
es en
100%
HelloMacOS님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Carlos
회원 가입일: 03/09/18
936 평판
안내서 4개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 14
30일 전: 43
전체 시간: 528
