주요 콘텐츠로 건너뛰기
Mercedes W123 Fuel Filler Neck Seal Replacement
필요한 것
  1. Mercedes W123 Fuel Filler Neck Seal Replacement, Fuel Filler Neck Seal: 1 단계, 이미지 1/1
    • When inspecting your fuel filler neck seal look for dryness, brittleness, or like on this particular diesel W123 obvious damage. This was caused by drips of B99 biodiesel on the already aged rubber seal.
  2. Mercedes W123 Fuel Filler Neck Seal Replacement: 2 단계, 이미지 1/1
    • Gently pry around the edge of the old seal with a flat blade screwdriver or a large plastic spudger type tool. The old seals often stick slightly to the car.
  3. Mercedes W123 Fuel Filler Neck Seal Replacement: 3 단계, 이미지 1/1
    • Pull the seal off of the fuel filler neck. It will look like this once the seal is off.
  4. Mercedes W123 Fuel Filler Neck Seal Replacement: 4 단계, 이미지 1/2 Mercedes W123 Fuel Filler Neck Seal Replacement: 4 단계, 이미지 2/2
    • Use your thumb to press the new seal in around the filler neck. The new seal has a lip on the back that must be pressed in to the hole around the neck. This lip will grip the metal edge of the hole for a tight seal.
  5. Mercedes W123 Fuel Filler Neck Seal Replacement: 5 단계, 이미지 1/1
    • Here's one last look at the damage done by the biodiesel. The owner of this W123 will be more careful in the future not to drip fuel on the filler neck seal when filling with B99; at that concentration, biodiesel is very caustic to rubber. Lesson learned!
결론
Once finished, consider covering the rubber seal in a light coating of silicone grease to help preserve it.
다른 10명이 해당 안내서를 완성하였습니다.
Nicolas Siemsen
회원 가입일: 12/06/13
38,247 평판
안내서 79개 작성하였습니다
Master Techs Master Techs 회원
Community
311 회원들
안내서 1,194개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 17
30일 전: 60
전체 시간: 7,674
