주요 콘텐츠로 건너뛰기
Mercedes W123 Glow Plug Fuse and Fuse Box, Early Style Replacement
필요한 것
  1. Mercedes W123 Glow Plug Fuse and Fuse Box, Early Style Replacement, Glow Plug Fuse and Fuse Box, Early Style: 1 단계, 이미지 1/1
    • The fuse box on early W123 cars, those with the glow plug relay inside the car and under the dash, usually 1980 and earlier, are located on the firewall back behind several of the soft rubber heater hoses. The location makes it difficult to photograph the fuse box when installed.
    • To uninstall the fuse box simply locate it on the firewall and remove the two Phillips head screws that hold it to the firewall. These are the Phillips screws located on the upper right and lower left corners of the fuse box, outside of the fuse box cover.
    • Once the fuse box is removed from the firewall it can be gently pulled forward for easier access to the screws holding the wires and fuse in place inside the box. As shown, once you've pulled the box out from under the coolant hoses you can remove the two remaining Phillips head screws and then remove the fuse box and old fuse.
  2. Mercedes W123 Glow Plug Fuse and Fuse Box, Early Style Replacement: 2 단계, 이미지 1/3 Mercedes W123 Glow Plug Fuse and Fuse Box, Early Style Replacement: 2 단계, 이미지 2/3 Mercedes W123 Glow Plug Fuse and Fuse Box, Early Style Replacement: 2 단계, 이미지 3/3
    • With the fuse box removed it and the fuse can be inspected. This fuse box was removed because excess heat caused the fuse box plastic to melt. This allowed the copper fuse connection on the left to be pulled to the right within the body of the fuse box. Eventually the two copper sections would touch, bypassing the fuse.
    • The old, damage box is shown on the left while the replacement box is shown on the right.
    • See how the fuse is bent in the middle as it's left-side connection was pulled to the right.
    • In this case this was caused by the timer on the glow plug relay no longer functioning after the glow system on the older style glow plug system after it was converted to the fast glow plug system. The glow plugs stayed hot, with 12V going through the fuse, while testing the window regulators on this car.
  3. Mercedes W123 Glow Plug Fuse and Fuse Box, Early Style Replacement: 3 단계, 이미지 1/1
    • Replace the fuse box with the new one, and install a new 80 or 50 amp fuse (check to see which fuse to use, depending on year and model). Screw in the two Phillips head screws that hold the glow plugs wires to the fuse and fuse box, and then reattach the new fuse box to the firewall.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nicolas Siemsen
회원 가입일: 12/06/13
39,010 평판
안내서 79개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,521개 작성하였습니다
댓글 한 개
I just replaced glow plugs in my Mercedes Benz 300 CD 1979 with new ones( not pencil type). Now as soon as I turn the key glow plug fuse burnt out. What did I do wrong?
Idrejorb - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 19
30일 전: 75
전체 시간: 16,059
