주요 콘텐츠로 건너뛰기
Mercedes W123 Glow Plug Test Technique
  1. Mercedes W123 Glow Plug Test Technique, Mercedes W123 Glow Plug Test Technique: 1 단계, 이미지 1/1
    • To perform this method of testing, you will need a reliable 12v power source. You could use a spare 12v battery and jumper cables. In this case, a battery "jumper" box was used.
    • If you are testing a glow plug that is new from the box, you can begin here.
    • If you are testing a plug that is currently in your engine to see if it is the bad plug, you will need to first remove it; see the glow plug replacement guide for advice on this process.
    • Start the test by gripping the body of the glow plug with the negative cable clamp.
  2. Mercedes W123 Glow Plug Test Technique: 2 단계, 이미지 1/1
    • Then attach the positive clamp to the threaded end of the glow plug. Be careful to not let the positive and negative clamps touch.
    • Pictured is a good, brand new Bosch glow plug lighting up nice and hot at the very tip. This is how the plugs should all perform.
    • Be extremely careful during this process! Never ever touch the tip, or place it on a flammable surface just after testing. The tip can reach temperatures over 1000F!
  3. Mercedes W123 Glow Plug Test Technique: 3 단계, 이미지 1/1
    • Shown here is a used glow plug that is not working quite right, despite glowing at the tip. The tip was slow to light compared to the new plug. You can also see that it is covered in carbon; it's a reminder that you'll want to ream the glow plug hole in the pre-chamber before installing a new one.
  4. Mercedes W123 Glow Plug Test Technique: 4 단계, 이미지 1/1
    • Shown here is a bad glow plug. It did not glow at all despite 12v being directly applied. This was the main culprit in this particular car's rough cold starts.
결론
When done testing, replace any bad glow plugs.
다른 5명이 해당 안내서를 완성하였습니다.
Nicolas Siemsen
회원 가입일: 12/06/13
39,040 평판
안내서 79개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,535개 작성하였습니다
댓글 2개
Muy Util su guia muchas gracias!!
Pippenpy - 답글
Thank you for your work. Very helpful.
Vitaliy Khutko - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 29
전체 시간: 7,081
