주요 콘텐츠로 건너뛰기
Mercedes W123 Over-voltage Protection Relay and Fuse Replacement
  1. Mercedes W123 Over-voltage Protection Relay and Fuse Replacement, Over-voltage Protection Relay and Fuse: 1 단계, 이미지 1/1
  2. Mercedes W123 Over-voltage Protection Relay and Fuse Replacement: 2 단계, 이미지 1/1
    • Look up inside below the dash, just beneath the furthest right side dash vent. You'll see the OVP relay with the red ruse on top.
    • Even if you are just checking the fuse, the easiest way to get access is to remove the entire relay. Simply pull it up and off of the black plug it is attached to, which sits beneath it.
  3. Mercedes W123 Over-voltage Protection Relay and Fuse Replacement: 3 단계, 이미지 1/1
    • This is the OVP relay out from under the dash.
    • The fuse on top slides in side-ways. It is a 10 amp fuse.
    • You can use a needle nose pliers to pull the fuse out of the holder that is attached to the relay.
  4. Mercedes W123 Over-voltage Protection Relay and Fuse Replacement: 4 단계, 이미지 1/1
    • As you can see here, the fuse was blown. The filament is broken internally.
    • Since this was the case, the fuse was replaced. The tachometer returned to normal function indicating that the fuse was the problem.
    • If the fuse continues to blow, the OVP relay may need to be replaced. If the fuse is not blow, you may need to test and/or replace the OVP relay.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Nicolas Siemsen
회원 가입일: 12/06/13
39,040 평판
안내서 79개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,528개 작성하였습니다
댓글 3개
Hi,
Thanks for the tutorial, does this apply to 1986 560sl?
Thanks,
Patrick
pepe - 답글
Hi guys just want to know what amp's are the 2 fuses
By the relay under the hood..thanks in advance
Charles Lottering - 답글
Hopefully this is my issue. I live in the San Joaquin Valley in California and my 1981 Mercedes 240d is my daily driver. The compressor was working but we are trying to get the auxiliary fan to come on when the AC comes on otherwise it doesn't cool properly. I replaced the radiator fan with an electric and didn't realize the auxiliary fan is not working so the AC would only start cooling when the electric radiator fan would kick on. When we were trying to see how to jump from the AC relay to the auxiliary fan relay we must have over charged the system and tripped the fuse because now the compressor won't engage.
Dan Hazen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 44
30일 전: 163
전체 시간: 27,681
