주요 콘텐츠로 건너뛰기
Mercedes W123 Radiator Hose Replacement
필요한 것
  1. Mercedes W123 Radiator Hose Replacement, Radiator Hose: 1 단계, 이미지 1/1
    • Begin by draining your radiator of coolant as [잘못된 안내서 링크]. You will not need to drain the block for this process.
    • As always, never work on your coolant system when it is hot. This is very very dangerous.
  2. Mercedes W123 Radiator Hose Replacement: 2 단계, 이미지 1/2 Mercedes W123 Radiator Hose Replacement: 2 단계, 이미지 2/2
    • Find your upper coolant hose connection at the upper driver's side of the radiator.
    • Loosen the hose clamp on this end of the hose.
  3. Mercedes W123 Radiator Hose Replacement: 3 단계, 이미지 1/1
    • Follow this hose to the top of the engine block, where it enters the thermostat housing.
  4. Mercedes W123 Radiator Hose Replacement: 4 단계, 이미지 1/1
    • Then use a hose clamp removal hook or other appropriate tools to work around under the edge of the hose. This will help break them free; they often stick to the necks they attach to over time.
    • Pull the hose off fully on both ends.
  5. Mercedes W123 Radiator Hose Replacement: 5 단계, 이미지 1/1
    • Continue by loosening the clamp on the lower radiator hose where it connects to the thermostat housing.
  6. Mercedes W123 Radiator Hose Replacement: 6 단계, 이미지 1/1
    • Then go underneath the car and loosen the clamp on the lower radiator hose where it connects to the radiator.
    • Remove the hose in the same manner you did the upper hose.
    • Now replace both hoses, and secure with hose clamps. Replace the hose clamps with new ones if they were difficult to open due to corrosion or stripped screw heads.
    • Finish by filling the system with coolant and bleeding the system as [잘못된 안내서 링크]
결론
다른 4명이 해당 안내서를 완성하였습니다.
Nicolas Siemsen
회원 가입일: 12/06/13
38,842 평판
안내서 79개 작성하였습니다
Master Techs Master Techs 회원
Community
319 회원들
안내서 1,354개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 33
전체 시간: 6,153
