소개
For such a small and inexpensive part the sway bar link on the rear suspension of W123's can create quite the racket.
If, as you drive or rough roads, you hear a lot of rumbling or clunking from the rear of the car the first place to check is the sway bar links. It's easy to diagnose, and almost as easy to replace. Do yours today; stop living with the noise!
필요한 것
You will need to begin by jacking up the rear end of your car, and removing the rear wheels. If you need help with these, see the guides below:
Remove the nut from the top of the sway bar link using a 17 mm socket to turn off the nut while holding the inside of the sway bar link joint with an open end 17mm wrench.
Then use the open end 17mm wrench to loosen the bottom joint of the sway bar from the hub assembly.
You'll then be able to remove the sway bar link for inspection. Save the nut and any washers as the new links do not come with replacements.
다른 9명이 해당 안내서를 완성하였습니다.
4가이드 댓글
Great photos and videos. Good job. Thanks.
Pat OBrien - 답글
You're welcome! This is definitely one of those repairs that are 1) easy and 2) provide a LOT of immediate tangible benefit. It's super annoying driving around with bad sway bar links.
Muchas gracias por tu trabajo, es de una gran ayuda. Tenía un "clonk" trasero cada que vez que pasaba por un pequeño bache y ahora ha desaparecido. Muchas gracias.
