필요한 것
Begin by removing the white plastic thumb screw that holds the turn signal to the body of the car.
You will find this screw just forward of the inside of the wheel well.
With the screw removed, pull the turn signal straight out away from the front of the car.
Do not pull the signal out and away from the headlight housing without first pulling it forwards as shown in the first picture. There are plastic tabs that fit in the openings highlighted in the second picture. These tabs can be easily broken if this step is not followed.
Once the tabs are clear of their slots you can move the tail light away from the headlight housing to get access to the bulb socket and wiring.
In the interest of preventing future corrosion consider also replacing the o-ring on the socket where it enters the housing.
On this car the o-rings were likely original and were fitting very loosely. They were likely allowing moisture to enter the housing.
Find a suitable replacement in your o-ring kit or at the local hardware store.
Coat the o-ring with a light coating of silicone grease to ease re-installation as the new o-ring may be a very snug fit. Also, the grease will help improve the seal and preserve the o-ring over time.
Install your new #1157 bulb in the socket, place the socket back in the housing and turn it clockwise to secure it, and the proceed to reconnect the socket to the plug and re-install the housing in the car.
Be sure to test the turn signals before going for a drive. The key will need to be all the way in the "ON" position in the ignition switch for the turn signals to function.
다른 7명이 해당 안내서를 완성하였습니다.
