소개
Windshield washer fluid might seem like kind of a boring topic; the only time it seems important is when you really need it most. Don't let a leaky bottle or bad pump ruin your day, replace them now.
  1. The windshield washer bottle is not attached to the car with any screws, nuts, or bolts. It simply sits in a bracket that holds it in place.
    • The windshield washer bottle is not attached to the car with any screws, nuts, or bolts. It simply sits in a bracket that holds it in place.
    • To remove your washer bottle pull it up and out of this bracket.
  2. If you are performing this job because your washer bottle is leaking now is the time to inspect the bottle for cracks.
    • If you are performing this job because your washer bottle is leaking now is the time to inspect the bottle for cracks.
    • If no cracks are found then inspect the spot where the pump enters that bottle.
    • The pump is not held in by any fasteners, instead it is a friction fit in a whole at the bottom of the bottle. There is a rubber grommet that seals this whole and seals the pump to the bottle. This grommet may be the source of your leak.
    • Whether you need a new bottle due to cracks, a new grommet due to leaks from the seal, or a new pump because the one on your car has failed, you will now need to remove the pump from the bottle. To do this pull the pump up, and then outwards away from the bottle.
  3. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. To replace the pump, start by unplugging the electric connection at the top.
    • To replace the pump, start by unplugging the electric connection at the top.
    • Then disconnect the plastic hose from the bottom.
    • Replace with new pump, reconnecting the electric connection and plastic hose.
  5. To finish, re-install the pump (old, if working, or new) in to your washer bottle (old, if good, or new, and possibly with new rubber grommet).
    • To finish, re-install the pump (old, if working, or new) in to your washer bottle (old, if good, or new, and possibly with new rubber grommet).
    • Then simply re-insert the bottle in to the retaining bracket.
    • On this car the pump worked fine, and the washer bottle and grommet were both OK. The bottle was simply very dirty and filled with really old, gross washer fluid. The bottle was simply removed, emptied, and cleaned and then refilled with a mix of water, isopropyl alcohol for freeze-prevention, and a few drops of dish soap.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Nicolas Siemsen
회원 가입일: 2013년 12월 06일
30,198 평판
안내서 79개 작성하였습니다
Master Techs Master Techs 회원
Community
280 회원들
안내서 783개 작성하였습니다
Any tips on installing the grommet? Should I put grommet on pump first then jam it in? Or should I put the grommet in the tank, then push the pump into it?
fezcabdriver - 답글
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 55
전체 시간: 4,893
