소개
If, like mine, the key head is broken and the key is therefore somewhat impractical to use, these instructions can help you.
필요한 것
In my case, the original cast key head tore and is therefore no longer stable, which made it somewhat impractical to use.
In the first step we need to remove the old potted key head. This works best with a sharp knife (cutter knife)
Now we take the new key head and insert the key.
If it's a bit difficult to get in, you can press down with something flat, like a slotted screwdriver.
If your key, like mine, is not straight but semi-circular, the fastening wedge must be adjusted. See Figures 2 and 3 for this
Now we are at the last step and it is very simple. Because you only have to insert the fastening wedge and the key head renewal is complete
I hope this guide has helped you.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
Migi님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
